LNitz
Use of SAS graphic macros such as DS2CONST in JMP
The SAS Macro, which calls Java Applets produces great plots of relationships that are hard to show when even moderately dense.  The plot of principal components or factor analysis of a data matrix  is often so dense that the points, let alone labels, cannot be identified.  The Treeview and DS2CONST macros make pretty attractive, open relationship graphs.
Has anyone tried these successfully in JMP?
Re: Use of SAS graphic macros such as DS2CONST in JMP
I am not familiar with this SAS macro. I have not seen the results that it produces. Perhaps you could supply some examples of the results that you find useful. Then we can help you to use JMP to produce these results.
If by "Has anyone tried these successfully in JMP?" you mean run the SAS macro in JMP, then that is possible if you can access a SAS Server locally or remotely. See the JMP Help about using JMP with SAS.
