  • Register to see how to import and prepare Excel data on Jan. 30 from 2 to 3 p.m. ET.
UersK
Use JSL to convert a 10 digit number into a 36 digit value?
For example, the value is 1234567890
Thanks!
Craige_Hales
Re: Use JSL to convert a 10 digit number into a 36 digit value?
I think you may be asking about base-36 representation. Hex() can do that with the optional base parameter.
hex(38,base(36))
"12"
that means the 1 is in the 36s place and the 2 is in the 1s place.
Just like in base 10, "38" has a 3 in the 10s place and an 8 on the 1s place.
For( i = 0, i < 100, i += 1,
	Write(
		Eval Insert(
			"\!n^i^₁₀  =  ^hex(i,base(36))^₃₆ \!t\!t^i+1000^₁₀  =  ^hex(i+1000,base(36))^₃₆ \!t\!t^i+1e6^₁₀  =  ^hex(i+1e6,base(36))^₃₆ \!t "
0₁₀  =  0₃₆ 		1000₁₀  =  RS₃₆ 		1000000₁₀  =  LFLS₃₆
1₁₀  =  1₃₆ 		1001₁₀  =  RT₃₆ 		1000001₁₀  =  LFLT₃₆
2₁₀  =  2₃₆ 		1002₁₀  =  RU₃₆ 		1000002₁₀  =  LFLU₃₆
3₁₀  =  3₃₆ 		1003₁₀  =  RV₃₆ 		1000003₁₀  =  LFLV₃₆
4₁₀  =  4₃₆ 		1004₁₀  =  RW₃₆ 		1000004₁₀  =  LFLW₃₆
5₁₀  =  5₃₆ 		1005₁₀  =  RX₃₆ 		1000005₁₀  =  LFLX₃₆
6₁₀  =  6₃₆ 		1006₁₀  =  RY₃₆ 		1000006₁₀  =  LFLY₃₆
7₁₀  =  7₃₆ 		1007₁₀  =  RZ₃₆ 		1000007₁₀  =  LFLZ₃₆
8₁₀  =  8₃₆ 		1008₁₀  =  S0₃₆ 		1000008₁₀  =  LFM0₃₆
9₁₀  =  9₃₆ 		1009₁₀  =  S1₃₆ 		1000009₁₀  =  LFM1₃₆
10₁₀  =  A₃₆ 		1010₁₀  =  S2₃₆ 		1000010₁₀  =  LFM2₃₆
11₁₀  =  B₃₆ 		1011₁₀  =  S3₃₆ 		1000011₁₀  =  LFM3₃₆
12₁₀  =  C₃₆ 		1012₁₀  =  S4₃₆ 		1000012₁₀  =  LFM4₃₆
13₁₀  =  D₃₆ 		1013₁₀  =  S5₃₆ 		1000013₁₀  =  LFM5₃₆
14₁₀  =  E₃₆ 		1014₁₀  =  S6₃₆ 		1000014₁₀  =  LFM6₃₆
15₁₀  =  F₃₆ 		1015₁₀  =  S7₃₆ 		1000015₁₀  =  LFM7₃₆
16₁₀  =  G₃₆ 		1016₁₀  =  S8₃₆ 		1000016₁₀  =  LFM8₃₆
17₁₀  =  H₃₆ 		1017₁₀  =  S9₃₆ 		1000017₁₀  =  LFM9₃₆
18₁₀  =  I₃₆ 		1018₁₀  =  SA₃₆ 		1000018₁₀  =  LFMA₃₆
19₁₀  =  J₃₆ 		1019₁₀  =  SB₃₆ 		1000019₁₀  =  LFMB₃₆
20₁₀  =  K₃₆ 		1020₁₀  =  SC₃₆ 		1000020₁₀  =  LFMC₃₆
21₁₀  =  L₃₆ 		1021₁₀  =  SD₃₆ 		1000021₁₀  =  LFMD₃₆
22₁₀  =  M₃₆ 		1022₁₀  =  SE₃₆ 		1000022₁₀  =  LFME₃₆
23₁₀  =  N₃₆ 		1023₁₀  =  SF₃₆ 		1000023₁₀  =  LFMF₃₆
24₁₀  =  O₃₆ 		1024₁₀  =  SG₃₆ 		1000024₁₀  =  LFMG₃₆
25₁₀  =  P₃₆ 		1025₁₀  =  SH₃₆ 		1000025₁₀  =  LFMH₃₆
26₁₀  =  Q₃₆ 		1026₁₀  =  SI₃₆ 		1000026₁₀  =  LFMI₃₆
27₁₀  =  R₃₆ 		1027₁₀  =  SJ₃₆ 		1000027₁₀  =  LFMJ₃₆
28₁₀  =  S₃₆ 		1028₁₀  =  SK₃₆ 		1000028₁₀  =  LFMK₃₆
29₁₀  =  T₃₆ 		1029₁₀  =  SL₃₆ 		1000029₁₀  =  LFML₃₆
30₁₀  =  U₃₆ 		1030₁₀  =  SM₃₆ 		1000030₁₀  =  LFMM₃₆
31₁₀  =  V₃₆ 		1031₁₀  =  SN₃₆ 		1000031₁₀  =  LFMN₃₆
32₁₀  =  W₃₆ 		1032₁₀  =  SO₃₆ 		1000032₁₀  =  LFMO₃₆
33₁₀  =  X₃₆ 		1033₁₀  =  SP₃₆ 		1000033₁₀  =  LFMP₃₆
34₁₀  =  Y₃₆ 		1034₁₀  =  SQ₃₆ 		1000034₁₀  =  LFMQ₃₆
35₁₀  =  Z₃₆ 		1035₁₀  =  SR₃₆ 		1000035₁₀  =  LFMR₃₆
36₁₀  =  10₃₆ 		1036₁₀  =  SS₃₆ 		1000036₁₀  =  LFMS₃₆
37₁₀  =  11₃₆ 		1037₁₀  =  ST₃₆ 		1000037₁₀  =  LFMT₃₆
38₁₀  =  12₃₆ 		1038₁₀  =  SU₃₆ 		1000038₁₀  =  LFMU₃₆
39₁₀  =  13₃₆ 		1039₁₀  =  SV₃₆ 		1000039₁₀  =  LFMV₃₆
40₁₀  =  14₃₆ 		1040₁₀  =  SW₃₆ 		1000040₁₀  =  LFMW₃₆
41₁₀  =  15₃₆ 		1041₁₀  =  SX₃₆ 		1000041₁₀  =  LFMX₃₆
42₁₀  =  16₃₆ 		1042₁₀  =  SY₃₆ 		1000042₁₀  =  LFMY₃₆
43₁₀  =  17₃₆ 		1043₁₀  =  SZ₃₆ 		1000043₁₀  =  LFMZ₃₆
44₁₀  =  18₃₆ 		1044₁₀  =  T0₃₆ 		1000044₁₀  =  LFN0₃₆
45₁₀  =  19₃₆ 		1045₁₀  =  T1₃₆ 		1000045₁₀  =  LFN1₃₆
46₁₀  =  1A₃₆ 		1046₁₀  =  T2₃₆ 		1000046₁₀  =  LFN2₃₆
47₁₀  =  1B₃₆ 		1047₁₀  =  T3₃₆ 		1000047₁₀  =  LFN3₃₆
48₁₀  =  1C₃₆ 		1048₁₀  =  T4₃₆ 		1000048₁₀  =  LFN4₃₆
49₁₀  =  1D₃₆ 		1049₁₀  =  T5₃₆ 		1000049₁₀  =  LFN5₃₆
50₁₀  =  1E₃₆ 		1050₁₀  =  T6₃₆ 		1000050₁₀  =  LFN6₃₆
51₁₀  =  1F₃₆ 		1051₁₀  =  T7₃₆ 		1000051₁₀  =  LFN7₃₆
52₁₀  =  1G₃₆ 		1052₁₀  =  T8₃₆ 		1000052₁₀  =  LFN8₃₆
53₁₀  =  1H₃₆ 		1053₁₀  =  T9₃₆ 		1000053₁₀  =  LFN9₃₆
54₁₀  =  1I₃₆ 		1054₁₀  =  TA₃₆ 		1000054₁₀  =  LFNA₃₆
55₁₀  =  1J₃₆ 		1055₁₀  =  TB₃₆ 		1000055₁₀  =  LFNB₃₆
56₁₀  =  1K₃₆ 		1056₁₀  =  TC₃₆ 		1000056₁₀  =  LFNC₃₆
57₁₀  =  1L₃₆ 		1057₁₀  =  TD₃₆ 		1000057₁₀  =  LFND₃₆
58₁₀  =  1M₃₆ 		1058₁₀  =  TE₃₆ 		1000058₁₀  =  LFNE₃₆
59₁₀  =  1N₃₆ 		1059₁₀  =  TF₃₆ 		1000059₁₀  =  LFNF₃₆
60₁₀  =  1O₃₆ 		1060₁₀  =  TG₃₆ 		1000060₁₀  =  LFNG₃₆
61₁₀  =  1P₃₆ 		1061₁₀  =  TH₃₆ 		1000061₁₀  =  LFNH₃₆
62₁₀  =  1Q₃₆ 		1062₁₀  =  TI₃₆ 		1000062₁₀  =  LFNI₃₆
63₁₀  =  1R₃₆ 		1063₁₀  =  TJ₃₆ 		1000063₁₀  =  LFNJ₃₆
64₁₀  =  1S₃₆ 		1064₁₀  =  TK₃₆ 		1000064₁₀  =  LFNK₃₆
65₁₀  =  1T₃₆ 		1065₁₀  =  TL₃₆ 		1000065₁₀  =  LFNL₃₆
66₁₀  =  1U₃₆ 		1066₁₀  =  TM₃₆ 		1000066₁₀  =  LFNM₃₆
67₁₀  =  1V₃₆ 		1067₁₀  =  TN₃₆ 		1000067₁₀  =  LFNN₃₆
68₁₀  =  1W₃₆ 		1068₁₀  =  TO₃₆ 		1000068₁₀  =  LFNO₃₆
69₁₀  =  1X₃₆ 		1069₁₀  =  TP₃₆ 		1000069₁₀  =  LFNP₃₆
70₁₀  =  1Y₃₆ 		1070₁₀  =  TQ₃₆ 		1000070₁₀  =  LFNQ₃₆
71₁₀  =  1Z₃₆ 		1071₁₀  =  TR₃₆ 		1000071₁₀  =  LFNR₃₆
72₁₀  =  20₃₆ 		1072₁₀  =  TS₃₆ 		1000072₁₀  =  LFNS₃₆
73₁₀  =  21₃₆ 		1073₁₀  =  TT₃₆ 		1000073₁₀  =  LFNT₃₆
74₁₀  =  22₃₆ 		1074₁₀  =  TU₃₆ 		1000074₁₀  =  LFNU₃₆
75₁₀  =  23₃₆ 		1075₁₀  =  TV₃₆ 		1000075₁₀  =  LFNV₃₆
76₁₀  =  24₃₆ 		1076₁₀  =  TW₃₆ 		1000076₁₀  =  LFNW₃₆
77₁₀  =  25₃₆ 		1077₁₀  =  TX₃₆ 		1000077₁₀  =  LFNX₃₆
78₁₀  =  26₃₆ 		1078₁₀  =  TY₃₆ 		1000078₁₀  =  LFNY₃₆
79₁₀  =  27₃₆ 		1079₁₀  =  TZ₃₆ 		1000079₁₀  =  LFNZ₃₆
80₁₀  =  28₃₆ 		1080₁₀  =  U0₃₆ 		1000080₁₀  =  LFO0₃₆
81₁₀  =  29₃₆ 		1081₁₀  =  U1₃₆ 		1000081₁₀  =  LFO1₃₆
82₁₀  =  2A₃₆ 		1082₁₀  =  U2₃₆ 		1000082₁₀  =  LFO2₃₆
83₁₀  =  2B₃₆ 		1083₁₀  =  U3₃₆ 		1000083₁₀  =  LFO3₃₆
84₁₀  =  2C₃₆ 		1084₁₀  =  U4₃₆ 		1000084₁₀  =  LFO4₃₆
85₁₀  =  2D₃₆ 		1085₁₀  =  U5₃₆ 		1000085₁₀  =  LFO5₃₆
86₁₀  =  2E₃₆ 		1086₁₀  =  U6₃₆ 		1000086₁₀  =  LFO6₃₆
87₁₀  =  2F₃₆ 		1087₁₀  =  U7₃₆ 		1000087₁₀  =  LFO7₃₆
88₁₀  =  2G₃₆ 		1088₁₀  =  U8₃₆ 		1000088₁₀  =  LFO8₃₆
89₁₀  =  2H₃₆ 		1089₁₀  =  U9₃₆ 		1000089₁₀  =  LFO9₃₆
90₁₀  =  2I₃₆ 		1090₁₀  =  UA₃₆ 		1000090₁₀  =  LFOA₃₆
91₁₀  =  2J₃₆ 		1091₁₀  =  UB₃₆ 		1000091₁₀  =  LFOB₃₆
92₁₀  =  2K₃₆ 		1092₁₀  =  UC₃₆ 		1000092₁₀  =  LFOC₃₆
93₁₀  =  2L₃₆ 		1093₁₀  =  UD₃₆ 		1000093₁₀  =  LFOD₃₆
94₁₀  =  2M₃₆ 		1094₁₀  =  UE₃₆ 		1000094₁₀  =  LFOE₃₆
95₁₀  =  2N₃₆ 		1095₁₀  =  UF₃₆ 		1000095₁₀  =  LFOF₃₆
96₁₀  =  2O₃₆ 		1096₁₀  =  UG₃₆ 		1000096₁₀  =  LFOG₃₆
97₁₀  =  2P₃₆ 		1097₁₀  =  UH₃₆ 		1000097₁₀  =  LFOH₃₆
98₁₀  =  2Q₃₆ 		1098₁₀  =  UI₃₆ 		1000098₁₀  =  LFOI₃₆
99₁₀  =  2R₃₆ 		1099₁₀  =  UJ₃₆ 		1000099₁₀  =  LFOJ₃₆
Those should be subscripts that look like
base 10, base 36base 10, base 36
You can go the other way too:
Hex To Number( "LFLY", Base( 36 ) );
1000006
Craige
Craige_Hales
hex(38,base(36))
"12"
	Write(
		Eval Insert(
1000006
Craige
