cerdmh
Use ComboBox on TableBox
Hi
I want to make a tablebox that one of it column eatch cell can have a value of "Yes" or "No"
thought of using a combobox for it
try using the following code with no success
new window("Bla Bla",
     tb = Table Box(
            c1 = String Col Box( "Bla Bla", {cb = combo box({"Yes","No"}) << get selected})
any idea
pmroz
Re: Use ComboBox on TableBox
Col boxes will do what you need:
new window("Combo Boxes in Tablebox",
	tb = Table Box(
		c1 = Col Box( "Bla Bla",
			cb1 = combo box({"Yes","No"}),
			cb2 = combo box({"Yes","No"}),
			cb3 = combo box({"Yes","No"}),
cerdmh
Thanks pmroz
Exactly what I needed
cerdmh
Thanks pmroz
I am not aware of being able to use a Combo Box() in a Table Box(), however, you can use a Check Box() to accomplish the same type of functionallity, as your Yes/No, but just by Check Box() selections
// Create a list of blank labels for the checkboxes
labelList = {};
For( i = 1, i <= N Rows( dt ), i++,
	Insert Into( labelList, "" )
// Create a display with a table box()
New Window( "Select Names",
	tb = Table Box(
		// Add the list boxes to the data table
		cb = Check Box(
			labelList,
				If( cb << get( i ) == 1,
					Print( dt:Name[i] )
		// Add the names from the data table
		scb = String Col Box( "Name", dt:Name << get values )
