DMR
DMR
Level V
Updating the Graph Builder's Element statement
Hi - I want to change the style of the Graph Builder's box-and-whisker plot to a plot of points from within a JSL script. The Graph Builder initially includes an Elements statement that looks like this:
				Elements( Box Plot( Y, Legend( 9 ) ) ),
I therefore want to modify that statement from within JSL to:
				Elements( Points( Y, Legend( 9 ) ) ),
I've found the << Add Element, << Update Element and << Remove Element commands for the GraphBuilderBox within the Scripting Index, but I can't work out how to apply them to achieve the effect I want. The example given in the Index (adding a regression line) doesn't directly relate to my situation, but I'm guessing that I need something like the following, where gb is my Graph Builder object:
report(gb)[GraphBuilderBox(1)] << Update Element(1, 1, 1, {Type("Points"), Y})
This evidently isn't right however - so I just need an example to show me what the correct syntax ought to be. Can anyone help me with this, please?
Many thanks.
jules
Re: Updating the Graph Builder's Element statement
I see just what your issue is now. Since you're using an X Grouping, and not an actual X variable, the indexing for the elements isn't standard. As per the docs:
obj << Get Element(xposition, yposition, i )
But, with an X Grouping, rather than an X, it seems that the first element isn't accessible with (1,1,1), (0,1,1), (.,1,1) or anything else I've tried.  So, here's what I came up with: temporarily define an X variable so you can access the element, and then remove the X variable once you've made the changes you need. I find it entirely inelegant, but it works. I'll try to find out if there is a proper way to access the elements when no X is defined so you don't need this workaround.
Open("$SAMPLE_DATA/Big Class.jmp");
gb = Graph Builder(
	Variables( Y( :height ), Group X( :sex ) ),
	Elements( Box Plot( Y, Legend( 10 ) ) )
wait( 1 );
gbb = Report( gb )[Graph Builder Box( 1 )];
//define an X temporarily
gbb << Add Variable( {:age, Role( "X" )} );
gbb << Remove Element(1, 1, 1);
gbb << Add Element(1, 1, {Type( "Points" ), X, Y, Legend( 5 )});
//remove the X
gbb << Remove Variable( {:age, Role( "X" )} );
jules
Hi @DMR,
Update Element() will change the properties of an existing element, but as far as I know will not allow you to change the type of element it is. Try deleting the existing element and adding a new one. Example below.
Hope this helps!
@jules
gb = Graph Builder(
	Size( 528, 448 ),
	Show Control Panel( 0 ),
	Variables( X( :age ), Y( :height ) ),
	Elements( Box Plot( X, Y, Legend( 4 ) ) )
Wait(1);
DMR
DMR
Level V
Hi Julian,
I'm closer to understanding the problem now, but unfortunately I'm still not quite there.  The difference between my situation and your example is that I'm using a discrete grouping variable instead of a continuous X variable: the following variation of your script illustrates the issue:
gb = Graph Builder(
wait( 1 );
// How do I modify the following two lines to replace the Box Plot above by Points?
If you can just show me how to modify the final two lines, the problem will be solved.
jules
gb = Graph Builder(
wait( 1 );
//remove the X
DMR
DMR
Level V
Inelegant it may be, but it works - and ultimately that's all that matters!
Many thanks.
