matt7109
Update values in window
Hi, the following code has a table box containg a number col edit box initialized to [1,2,3]. However, I would like for when the button named "Change Vals" is pressed, to update the values in the number col edit box to [4,5,6]. How can I go about doing this? Code show below..
list = [1, 2, 3];
New Window( "Test",
	Button Box( "Change Vals", list = [4, 5, 6] ),
	Table Box( String Col Box( "Col 1", {"One", "Two", "Three"} ), Number Col Edit Box( "Col 2", list ) )
Thanks!
Jeff_Perkinson
Re: Update values in window
You need a reference to your Number Col Edit Box and you can use the Set Values() message to change the values.
Like this.
list = [1, 2, 3];
New Window( "Test",
		list = [4, 5, 6];
		foo << set values( list );
	Table Box(
		foo = Number Col Edit Box( "Col 2", list )
-Jeff
Jeff_Perkinson
Like this.
list = [1, 2, 3];
New Window( "Test",
		list = [4, 5, 6];
	Table Box(
-Jeff
