  • Due to inclement weather, JMP support response times may be slower than usual during the week of January 26.
    To submit a request for support, please send email to support@jmp.com.
    We appreciate your patience at this time.
doctorfizz
Update an Associative array that is a class global variable
I have a class variable that is an associative array
define class (
"class name",
ass_array  = associative array ();
meth1 = method({x,y},
for(i = 1, n <= n items(x),i++
xi = x[i];
yi = y[i];
try(
ass_array  << insert(xi, Insert(eval list(ass_array[eval(xi)]), eval(yi))),
ass_array  << insert(xi, List(eval(yi)))
but when I call this class to update the associative array, the array is still empty. Any thoughts?
It is also worth noting that I tested this syntax external to the class to update an associative array and it acted as expected.
Re: Update an Associative array that is a class global variable
I think you might want to add initialization method
Define Class("class name",
	ass_array = Associative Array();
	_init_ = Method({},
		this:ass_array = ass_array;
	meth1 = Method({x, y},
		For(i = 1, i <= N Items(x), i++,
			xi = x[i];
			yi = y[i];
			Try(
				ass_array << Insert(xi, Insert(Eval List(ass_array[Eval(xi)]), Eval(yi))),
				ass_array << Insert(xi, List(Eval(yi)))
cn = New Object("class name");
show(cn:ass_array);
cn:meth1({"a", "b"}, {"c", "d"});
show(cn:ass_array);
this isn't necessary and I'm not sure if it should even be used (but it is used here https://www.jmp.com/support/help/en/18.0/#page/jmp/advanced-classes.shtml#ww761769)
	_init_ = Method({},
			xi = x[i];
			yi = y[i];
			Try(
show(cn:ass_array);
show(cn:ass_array);
doctorfizz
so, I have an init method. I did not put the entire workflow of the class out of laziness. I did not think it was necessary to troubleshoot the problem.
doctorfizz
But, instantiating the variable with the this:array seemed to have worked.
Why does this make a difference?
How to use Define Class might give some explanation
