Update a table from a database ?
Hi everybody,
I have a table with formulas and I want to update it with values from a database.
When I run " Update from a DB", I have a new table with the values from my database but I don't have formulas.
I don't underdand how this update works.
Is someone could help me please ?
Thank you !!!
Re: Update a table from a database ?
Hello Jean-Marc,
Update table will generate a new table if the number of columns has changed between the source table with the update table script, and the table in the database. In your case, because you have created formula columns this will be flagged as a difference, and a new table will be generated.
Because of feedback like this, JMP 12.1 and beyond will update the table in place IF the only difference are formula columns, and IF those formula columns are all at the end (rightmost) in the column list.
Brian Corcoran
JMP Development
Hello Jean-Marc,
Brian Corcoran
JMP Development
Thank tou for your answer.
So, How Can I do with JMP 11 ?
I'm afraid there is nothing that can be done in V11.  You will get a new window for the table.  You could join the two tables afterward, or use a JSL script to add the formula columns into the new table.
Brian
Thank you for your answer
