YenThe
New Member
Unable to find the Scripting-Tools Addins location link
I am interested to share this addins with my co worker but the link is no longer exists.
https://community.jmp.com/t5/JMP-Add-Ins/Scripting-Tools/ta-p/410943
is there a new link for JMP addins in general?
Re: Unable to find the Scripting-Tools Addins location link
It is definitely easiest if you still happen to have the add-in installers.
If you do not, you could share your whole add-in folder  Scripting Guide > Creating Applications > Create Add-Ins with the JMP Add-In Builder > Installing M... . You might have to share some extra files AND edit them but I dont' remember anymore which (I used this method when I moved my add-ins from one laptop to another with different username). They might have been the addinRegistry.xml files.
Or in my opinion better option (but takes more time) is to rebuild the add-ins. I think you could script this or you can use Add-In Manager addin and then pointing it to the add-in folder directly. It is able to pick most of the things to rebuild the add-in.
There was a post similar to this very recently: Access to JMP User Community Add-ins section - Insufficient privileges
Access to JMP User Community Add-ins section - Insufficient privileges  as a new post as JMP Community is messing something up with tagging posts
YenThe
New Member
Hi Jarmo, is there anyway I can share the previous addins that i have installed to my colleague? Since mostly the addins is no longer available from JMP Marketplace.
