TWE
TWE
UPDATE JOIN SQL statement with JMP tables
I would like to update via SQL statement the :age column in dt1 with the values of dt2.
dt1 = Open( "$SAMPLE_DATA/Big Class.jmp", output table("t1"));
dt2 = subset(dt1);
dt2:age[1] = 99;
Query(
	Table( dt1, "t1" ),
	Table( dt2, "t2" ),
		UPDATE t1
		SET
			t1.age = t2.age
		FROM
			t1
		INNER JOIN
			t2
		ON
			t1.name = t2.name
I got an syntax error near "."
Thanks
ih
Super User (Alumni) ih
Re: UPDATE JOIN SQL statement with JMP tables
I'm not sure if JMP understands SQL related to UPDATE queries, based on this statement failing with "Query failed: table t1 may not be modified in access or evaluation..." I'm not sure this is possible.
Query(
	Table( dt1, "t1" ),
	"UPDATE t1 SET age = 10"
You can, however, do this with Update:
dt1 << Update(
	With( dt2 ),
	Match Columns( :name = :name ),
	Replace columns in main table(:age)
If you have a more complex sql statement, you could create a SELECT query first using SQL to create a new table, then use this update function to update your original table.
ih
Query(
	Table( dt1, "t1" ),
dt1 << Update(
	With( dt2 ),
TWE
TWE
This works.
Many thanks!
