lwx228
Level VIII
How to find the mode of multiple columns and partial rows?
For example, add new columns with "Big Class. JMP ", and find the mode of the data in the same row of the "height"、"weight" columns and the five rows above.
Thanks!
mode(Range(:weight[Index(Row()-5,Row())], :height[Index(Row()-5,Row())]))
Re: How to find the mode of multiple columns and partial rows?
Here is the formula that I came up with
If( Row() > 6,
	Mode( Matrix( :height[Index( Row() - 5, Row() )] ) || Matrix( :weight[Index( Row() - 5, Row() )] ) ),
	Mode( Matrix( :height[Index( 1, Row() )] ) || Matrix( :weight[Index( 1, Row() )] ) )
Note: The Range() function returns the minimum and maximum values found in the list or matrix
Note: JMP returns the minimum mode value if there is more than one mode
mode([77,55,33,77,55])
returns
55
while
mode([55,34,67,88,65])
returns
34
6 REPLIES 6
lwx228
Level VIII
  • I can't get the right answer by using this formula.
Thanks!
If( Row() > 6,
returns
55
while
returns
34
lwx228
Level VIII
Thank Jim!
The JMP mode formula seems rather lax.
In Excel, no mode is returned as "#N/A", and JMP is returned as "minimum".
The minimum is a correct mode.  There just happens to be more than one mode.
lwx228
Level VIII
Whether this can be verified
It is a simple matter to determine if more than one value was found that determined what the mode is.  If you want to set the resulting mode to a missing value when the mode comes from a single value, you can use the below logic
mat = [1, 2, 3, 4, 5, 1];
xmode = Mode( mat );
If( N Rows( Loc( mat, xmode ) ) == 1,
	x = .
Show( xmode );
