lwx228
Level VIII
Two questions for "Big Class Families.JMP"
1. Can the picture in the "picture" column be imported from the computer's hard drive or from the Internet?
For example, how to use the JSL implementation to add "c:\1.png" to dt[1,1].
2. How the script "Graph Builder with Pictures"s:
"UniqueID(1180683047)," and "Origin({70.1036850751071, 172.033784817876})," are determined.
How can these numbers be computed using functional formulas?
ian_jmp
Level X
Re: Two questions for "Big Class Families.JMP"
For part of question 1, something like:
NamesDefaultToHere(1);
pic = Open( "$SAMPLE_IMAGES/tile.jpg", jpg );
dt = New Table( "Table with Images",
				Add Rows( 1 ),
				New Column( "Image Column",
					Expression,
					"None",
					Set Selected,
					Set Values( {Empty()} )
Wait(3);
Column(dt, "Image Column")[1] = pic;
lwx228
Level VIII
"UNIQUEID (1180683047)," I cannot find it in the original file.
Thanks Experts!
ian_jmp
Level X
				Add Rows( 1 ),
					Expression,
					"None",
					Set Selected,
Wait(3);
lwx228
Level VIII
Thanks ian! I finally learned the principle.
lwx228
Level VIII
I continue to ask: how to use JSL directly on the screen and then write dt[1,1].
For example, take a screenshot of the logo in the upper left corner of the JMP.com page and write dt[1,1].
Thanks Experts!
lwx228
Level VIII
  • Try this, too. Thank you very much!
pic = Open( "http://……=000001", png );
				Add Rows( 1 ),
					Expression,
					"None",
					Set Selected,
Wait(3);
