Discovery Summit 2026: Early User Edition - September 23-24.Register. It's free.
I have read in a reference book for R that the title 'Tukey Kramer' refers to the Tukey tests where there are unequal group sizes. The inference being that Tukey HSD requires groups to be of equal size. JMP refers to 'Tukey HSD (also called Tukey Kramer)' in the section
See the attached journal. Using Bigclass.jmp, you can see that the Fit Y by X, Compare Means -> All Pairs, Tukey HSD, for height by sex, does not require equal group sizes.
Fit Y by X.jrn
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '62107' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '62107') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '62107') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
