To open a file through JSL, how can I open the file in a shared way?
Mar 7, 2024 02:19 AM(1620 views)
For example, if I open a test.CSV file through JSL, how can I use other software to continue to add data to the test.CSV file and save it as a new one? Of course, there is no need to notify JMP when there is new data.
