Thanks, but I've gotten into the habit of using the red triangle drop down to lock the data table, and Get Edit Lock() returns empty, which doesn't make sense. My expectation is that it should return a list: {"Modify Cells", "Add Rows", "Delete Rows", "Add Columns", "Delete Columns"}, when the table is locked either through the drop down or Lock Data Table(1).
