Georg
Taylor Graph Builder expression
Dear Community,
I would like to make a Graph Builder Script (want to put that as script in a new table) that contains a long list of y vars.
My first approach was to try expression manipulation, but this did not work as expected.
Can anyone please explain what would be a good way to write that script?
The example below also contains my current way, creating the GB instance, and adding y vars afterwards.
Thanks and best regards,
cdt = Open( "$SAMPLE_DATA\Big Class.jmp" );
col_lst = cdt << get column names( Continuous, "String" );
gb_expr = Expr(
	cdt << Graph Builder(
		Size( 534, 450 ),
		Variables( X( :age ), Y( :height ) ),
		Elements( Position( 1, 1 ), Points( X, Y, Legend( 4 ) ) ),
		Elements( Position( 1, 2 ), Points( X, Y, Legend( 5 ) ) )
// this does not work, Expr() does not accept comma separated items
// Substitute Into( gb_expr, Expr( Y( :height ) ), Expr( Y( :height ), Y( :weight ) ) );
// gb_obj = gb_expr;
// this works
// creating GB instance
gb_obj = cdt << Graph Builder(
	Size( 534, 450 ),
	Variables( X( :age )),
// adding Y's
For Each( {ycol}, col_lst, Eval( Parse( Eval Insert( "gb_obj << variables( Y(:^ycol^ ))" ) ) ) );
// this I would like to create directly, w/o large parse/eval parts, that are bad for maintenance
my_target_expression = gb_obj << get script();
Georg
Re: Taylor Graph Builder expression
I am not aware of how to get around the Substitute issue.  You may want to explore the Scripting Index Graph Builder messages that can be passed to Graph Builder
gb = Graph Builder(
	Variables( X( :sex ) ),
	Elements( Points( X, Y ), Smoother( X, Y ) )
gb << Add Variable( {:height, Role( "Y" )} );
gb << Add Variable( {:weight, Role( "Y" )} );
@Georg
Building on @txnelson's suggestion about sending messages to graph builder, this might get you closer to what you are looking for:
cdt = Open( "$SAMPLE_DATA/Big Class.jmp" );
gb = Graph Builder(
	Variables( X( :age ) ),
	Elements( Points( X, Y ) )
for each( { yCol }, col_lst,
	gb << Add Variable( { eval( yCol ), Role( "Y" ) } );
The resulting graph builder script is:
Graph Builder(
Variables( X( :age ), Y( :height ), Y( :weight ) ),
Elements( Position( 1, 1 ), Points( X, Y, Legend( 1 ) ) ),
Elements( Position( 1, 2 ), Points( X, Y, Legend( 2 ) ) )
-Scott
Might this minor change to use Eval(Eval Expr()) provide you with what you want
gb_expr = Expr(
		Size( 534, 450 ),
// this works
	Size( 534, 450 ),
// adding Y's
	Eval( Eval Expr( gb_obj << variables( Y( Expr( ycol ) ) ) ) )
Georg
Hi Jim,
thanks, this works as well using eval/evalexpr.
But my question was, how could I build that full gb_expr in the upper part,
my showstopper was, that:
did not work.
So I want to substitute many "Y(:c1), Y(:c2) ..." into the Graph Builder expression using expression manipulation (not string manipulation).
Best regards,
Georg
gb = Graph Builder(
@Georg
gb = Graph Builder(
Graph Builder(
-Scott
Georg
Thanks to all, that looks good!
Georg
I don't usually use substitute for that but rather build them using expressions, below is one option but there are other options
dt = Open("$SAMPLE_DATA\Big Class.jmp");
col_lst = cdt << get column names(Continuous, "String");
var_expr = Expr(Variables(X(:age)));
For Each({colname}, col_lst,
	colname = "height";
	Insert Into(var_expr, EvalExpr(Y(Expr(Name Expr(As Column(dt, colname))))));
gb_expr = EvalExpr(
		Size(534, 450),
		Show Control Panel(0),
		Expr(Name Expr(var_expr))
gb = Eval(gb_expr);
// gb << get script
gb << Save Script to Data Table("Plot");
If you just want to use Substitute, I think you will have to substitute the whole Variables part (or possibly do some tricks)
cdt = Open("$SAMPLE_DATA\Big Class.jmp");
gb_expr = Expr(
		Size(534, 450),
		Variables(X(:age), Y(:height)),
		Elements(Position(1, 1), Points(X, Y, Legend(4))),
		Elements(Position(1, 2), Points(X, Y, Legend(5)))
Substitute Into(gb_expr, Expr(Variables(X(:age), Y(:height))), Expr(Variables(X(:age), Y(:height), Y(:weight))));
show(gb_expr);
