hogi
Level XIII
Talking to Display boxes
The auto-generated script to generate this plot
is
Graph Builder(
	Variables( X( :height ), Y( :weight ), Overlay( :sex ) ),
	Elements( Points( X, Y, Legend( 1 ) ), Smoother( X, Y, Legend( 2 ) ) ),
	SendToReport( Dispatch( {}, "X title", TextEditBox, {Set Text( "xxx" )} ) )
- Why "X title"?
- What is a robust way to talk later with the X axis title.
current Report()[TextEditBox(3)]
seems to work - but is there something with "X axis" included in the command?
Re: Talking to Display boxes
Not sure if there are any "direct" ways of accessing that axis title, but you can use Dispatch (which to my knowledge should be avoided...)
gb = dt << Graph Builder(
	Size(520, 176),
	Show Control Panel(0),
	Variables(X(:height), Y(:weight), Overlay(:sex)),
	Elements(Points(X, Y, Legend(13)), Smoother(X, Y, Legend(14)))
Report(gb) << Dispatch(
	"X title",
	TextEditBox,
	{Text Color("Red"), Set Base Font("Heading"), Font Color(3)}
hogi
Level XIII
yes, right, these 2 considerations have led me to write the question.
