ileshem
Take value from specific cell to create a column
In JSL, I want to use a specific cell value to create a column. how can I do it?
From this:
ID
1122
NameAge
Johan23
David34
Jack27
to This:
IDNameAge
1122Johan23
1122David34
1122Jack27
Re: Take value from specific cell to create a column
For this specific case this should work:
dt = New Table("Untitled 5",
	Add Rows(6),
	Compress File When Saved(1),
	New Column("Column 1",
		Character,
		"Nominal",
		Set Values({"ID", "1122", "Name", "Johan", "David", "Jack"})
	New Column("Column 2",
		Character(16),
		"Nominal",
		Set Values({"", "", "Age", "23", "34", "27"})
wait(1);
//get column name
columnNameCell = dt[1,1];
//get cell value
valueCell = dt[2,1];
//Rename columns
Column(dt,1) << Set Name(dt[3,1]);
Column(dt,2) << Set Name(dt[3,2]);
//Remove extra rows
dt << Delete Rows([1,2,3]);
//create new column
dt << New Column(columnNameCell, Character, Nominal, << Set Each Value(valueCell));
//Move ID column
dt << Move Selected Columns(:ID, To First);
For modifications like this I think Data Table Subscripting is very helpful
Craige_Hales
nice! I don't think I understood the question until I ran your answer a line at a time.
Craige
