anne_sa
Tabulate question
Hello everybody,
I have a question regarding the Tabulate report.
Here is an example using the Big Class data table.
What I would like to display is only the mean value for height and only the maximum value for weight. I know it is feasible when the variables are in columns but I didn't manage to do it when they are in rows. Maybe there is a drag and drop trick to do it...
Thanks in advance for your help!
dale_lehman
Re: Tabulate question
Attached is the Big Class data with an additional script titled "Will this work?" which I think is what you are asking for.  Instead of dragging height and weight into the rows part of the dialog, I only put sex as rows and age as columns.  Then select height and mean and drag that into the table (use control to select both weight and the mean, then release control and drag the combo into the table).  Then select weight and max and drag that into the body of the table.  You'll get both means and max for both weight and height, but I think it is arrayed the way you want.
anne_sa
Thanks for your answer @dale_lehman
However my main formatting issue is that I would like to have the mean of height and not the max, and the max of weight but not the mean. But maybe it's not feasible?
dale_lehman
You can make the tabulation into a data table and then remove the unwanted columns.  Quite likely, someone can give you a scripted solution that will make it into a data table and remove the unwanted columns at the same time.  But I don't know of a way to create the tabulation without getting the mean and max for both weight and height - if you want them broken down by sex and age.
ian_jmp
Level X
Not sure if this is what you are after:
If so, you can do this via 'drag and drop' by having two row tables.
anne_sa
Hi @ian_jmp ,
That's pretty closed indeed thanks for your suggestion!
Actually the "exact" template I had in mind was something like that:
But maybe I have to put it on the JMP Wish List (since Christmas is coming :)
