Level XIII
Tables/Update changed!
Please note, there is a significant change of the Tables/Update functionality in JMP19.
dt = Open( "$SAMPLE_DATA/Big Class Families.jmp" );
// Update data table
Data Table( "Big Class" ) << Update(
	With( Data Table( "Big Class Families" ) ),
	Match Columns( :name = :name, :age = :age ),
	Replace Columns in Main Table( None )
Available columns after executing the script 1x, 2x  and 3x in JMP18 *):
*) after adding new columns in the first step, no new columns are added. JMP informs the user:
Available columns after executing the script 1x, 2x  and 3x with JMP19:
The new feature seems to be triggered by this post in the Wish List:
Allow Update platform to create new columns if they already exist in the table to be updated
This wish is great, as an option - but it might collide with how other users used Tables/Update up to now.
Especially dangerous if scripts are affected.
Can the new functionality be disabled?
Re: Tables/Update changed!
Hi @hogi ,
Best place to pose this question would be to [email protected] - they'll better handle this issue.
Ben
Level XIII
hi @Ben_BarrIngh , communication with JMP support is running in parallel: TS-00236061
up to now, no solution available how to get rid of the issue.
Seems that Tables/Update cannot be used anymore for "add all additional columns from the other table".
Level XIII
Added as a proposal to the wish list:
automatic tables/update
Level XIII
The above example might look artificial.
Here is an example that is closer to real life:
dtall=new table("data collection",<< add rows(1),New column("identifier", set value(1)));
for(i=1, i<20, i++,
	dt= new table("tmp", add rows(1),
		New column("identifier", set value(1)), Private
	wait(0);
	if(or(i==1,  random integer(10)>2),
		dt << New column ("date") << New column ("time") <<	New column ("site") << New column ("vendor") <<	New column ("country") <<	New column ("status")
	New column ("value_"|| Char(Random integer(1000)));
	dtall << Update(
	With( dt ),
	Match Columns( :identifier = :identifier ),
close(dt, noSave)
In every data table, there are measurement values value_xyz and sometimes there is redundant (or unnecessary) data.
Data collection in JMP18: just the measurement values are added
Data Collection in JMP19: significant growth of the data table due to added redundant/duplicate or unnecessary data.
One might argue that it is better to add status (tmp2) 5 to the data collection than to lose this information.
Yes, there are definitely many cases where the new functionality is an improvement on the old.
However, it is undeniable that the new functionality significantly interferes with how the old platform could be used.
and with many thousand users worldwide such a change is dangerous.
