Metin_Tueluemen
Table Update from Access Database do not work with jmp 16
In our company there is an access database for rheology measurements. We can update rheology jmp tables from this database file (.mdb) by using jmp 14.3. Now we are using jmp 16.2 and the update script do not work anymore. Every time I have to open jmp 14 to update the tables.
Current Data Table() << Update From Database(
	"DSN=Test;DBQ=filelink\filelink\file.mdb",
	"SELECT * FROM [file]"
Re: Table Update from Access Database do not work with jmp 16
Check the log. What happens when it doesn't work?
Did you switch from 32 bit to 64 bit JMP? Might be a driver mismatch if so.
Tech support can definitely help, link at bottom of page.
