- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Get Direct Link
Table Update: How to update only selected columns?
This should be a quick one:
Table update: How to update only selected columns?
Data Table( dt1 ) << Update(
With( Data Table( dt10 ) ),
Match Columns( :SAMPLE = :SamID ),
Add Columns from Update Table( None ), ### Update Selected Columns (:Type, :Method) ###)
It's simple when done manually, but in the script? There's nothing in the scripting guide (only how to avoid adding columns). My various guesses and trials (eg. see inside ### in above script) do not work.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Re: Table Update: How to update only selected columns?
If you have JMP16 you can perform the action once manually and then get the script from enhanced log, most likely what you are looking for is Replace Columns in Main Table()
Data Table("Big Class") << Update(
With(Data Table("Subset of Big Class")),
Match Columns(:name = :name),
Replace Columns in Main Table(:age)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Created:
Feb 27, 2023 08:58 AM
| Last Modified: Feb 27, 2023 6:00 AM
(1654 views)
| Posted in reply to message from jthi 02-27-2023
HI, this will probably do what you are looking for
// opens Table
dt1 = Open( "$SAMPLE_DATA/Big Class.jmp" );
//generate update Table
dt2 = dt1 << Clear Select << Select Rows( Index( 1, 8 ) ) << Subset( Selected Rows( 1 ), Selected columns only( 0 ) );
// delete contend
for(k=4,k<=ncols(dt1),k++,column(dt1,k)[(1 :: 8)]=.);
//select columns
dt1 << Clear select;
wait(0.1);
dt1 << Select Rows ( (3::5) );
wait(0.1);
// ### scrpit only with selected rows
// get selected rows
s_rows = dt1 << Get Selected Rows();
// create a new column with selected rows as 1
n_c1 = dt1 << new column();
n_c1[s_rows]=1;
// create a new column on the update table
n_c2 = dt2 << New Column("temp",Numeric,"Continuous",<<Set Initial Data( 1 ));
// update only where the 1 is present (selected rows only)
dt1 << Update(
With( dt2 ),
Match Columns( :name = :name, n_c1 = n_c2 ),
// delete the columns
dt1 << Delete Columns(n_c1);dt2 << Delete Columns(n_c2);
"I thought about our dilemma, and I came up with a solution that I honestly think works out best for one of both of us"
- GLaDOS
- GLaDOS
