MarkDayton
Table Scripts and the Parent Data Table
I have a set of scripts that I copy to new data tables. To make sure that when I run the table script it acts on the data table it belongs to I have to edit all of the scripts to point to the right data table (dt = Data Table("this one")). Is there a generic way to reference the parent data table, similar to dt = Current Data Table(), but more like dt = Parent Data Table()?
13 REPLIES 13
MarkDayton
Re: Table Scripts and the Parent Data Table
I thought about that, and I may give it a try, but I've decided to just go with David's suggestion and run the scripts from the data table so the Current Table will be the one I want. If I run the script from the editor, I'll just have to be more careful. Question, when writing a script to create table scripts, can comments be included in the table scripts?
MarkDayton
In answer to my own question no, comments are not included when using a script to add a script to a data table, the comments are stripped out just like they are when you copy scripts from one table to another (why anyone would think this was a desirable default behavior is beyond me, if I take the time to add comments to a script why would I want to throw them away anytime I go to use that script somewhere else).
David_Burnham
OK I asumed you were just running it as a table script using the green triangle.
-Dave
MarkDayton
Thanks David, appreciate the help.
