david707
Syntax and meaning of numbers in a DispatchSeg( Hist Seg( 1 ), Bin Span( x, y ) ) command
I am trying to adjust the bin sizes of the histogram in a oneway analysis report, I am aware that this has been asked and answered before and you need to use:
DispatchSeg( Hist Seg( 1 ), Bin Span( x, y ))
However, previous answers say to look at the scripting index for more information, and I cannot find anything about this on the scripting index.
I cannot figure out how x and y actually relate to the bin sizes, and how to get the sensible bin sizes I want.
Can someone please clarify exactly how x and y effect the bin sizes?
Thanks
Re: Syntax and meaning of numbers in a DispatchSeg( Hist Seg( 1 ), Bin Span( x, y ) ) command
Through a bit of trial and error, I've come to the conclusion that Bin Span (x, y) works out to:
x = the size of each bin; same function as using the hand tool and dragging horizontally
y = the offset of each bin; same function as using the hand tool and dragging vertically
(This holds true for the ANOVA platform--I didn't check with other histograms)
The code below demonstrates this with the Big Class sample file.
Names Default To Here (1);
dt = open ("$SAMPLE_DATA/big class.jmp");
//a bin for each data point
Oneway(
	Y( :weight ),
	X( :age ),
	Histograms( 1 ),
		Dispatch(
			"Oneway Report",
			FrameBox,
			{DispatchSeg( Hist Seg( 1 ), Bin Span( 1, 0 ) )}
//huge bin
Oneway(
	Y( :weight ),
	X( :age ),
	Histograms( 1 ),
		Dispatch(
			"Oneway Report",
			FrameBox,
			{DispatchSeg( Hist Seg( 1 ), Bin Span( 100, 0 ) )}
//medium bins with some offset
Oneway(
	Y( :weight ),
	X( :age ),
	Histograms( 1 ),
		Dispatch(
			"Oneway Report",
			FrameBox,
			{DispatchSeg( Hist Seg( 1 ), Bin Span( 10, 50 ) )}
david707
I guess my question is how does "size" relate to the data set and/or axis?
It seems really arbitrary with different data sets and axis.
Size 10 might look great on one graph and terrible on another.
I completely agree. This Wikipedia article has about 10 different "rules of thumb" for determining bin sizes. In my experience, I've generally just accepted what JMP offers, and if I have questions about the shape, I switch to a Shadowgram, which avoids the bin size question altogether.
