nbullen
Summarize Without Alphabetizing
I have a dataset where the order is important and I want to be able to summarize a character column with repeat values without the results being in alphabetical order.
column_A
f
f
b
b
b
d
a
a
c
c
c
e
e
Usual methods return {a,b,c,d,e,f},
I am trying to get {f,b,d,a,c,e}
Please advise.
nbullen
Re: Summarize Without Alphabetizing
Sometimes, just by asking you end up freeing your mind to possible solutions. I give to you, the non-alphabetizing summarizer:
no_sort_summarize = function({list},
	design_matrix = Design( list, list ); //compares the list to itself returning a 1 in the position of the first match for each repetition
	summarized_matrix = (Transpose(V Sum(design_matrix))); //flatten matrix into one row and transpose into columns
	unique_value_positions = Loc(summarized_matrix); //return only the position of the first instance of a value thus creating a summary
	return(list[unique_value_positions]); //subscript list to return the non-sorted summarized values
I can officially confirm that Summarize() does now support the Value Ordering property as of JMP 14 and later.
8 REPLIES 8
nbullen
If the order you want to summarize by is the order found in the data, you can set the column property, "Row Order Level" for Column_A, and then run
     Tables==>Summary
and the data will be summarized in the order the grouping column was found in the data table
dale_lehman
And, more generally, you can use the Value Ordering column property to impose whatever order on the variable you wish.  That order will be used in any subsequent analysis (tablulation, graphs, etc.).
Jeff_Perkinson
Unfortunately, in JMP 13 and earlier the Summarize() JSL function doesn't respect the Value Ordering property.
I've confirmed that this will be corrected in JMP 14.
-Jeff
dale_lehman
Another reason I'm glad I rarely script anything - Tabulate works just fine with Value Ordering.
PhiIippe
Hi Jeff,
I have JMP 14, but my summarize() function is still alphabetic, does the non-alphabetic version have another name?
Philippe
I have tried setting the Value Ordering column property for both numeric and character columns under JMP 14.3 and the Summarize() function uses the Value Ordering property as it's order.
