Substituting a space for underscore in a character string
Created:
Feb 4, 2023 01:07 PM
| Last Modified: Jun 8, 2023 9:38 AM(3968 views)
Hi:
I have a long description of a product that includes a bunch of underscores __ which I don't want. I'd like to replace them with spaces instead.
I've tried using substr(substitute(columnname, "_",""),1, 999) but that just makes the entire field blank. I've also tried the reverse (substitute(substr....) same problem.
Hi, notice that Jarmo's code replaces the underscores with a space character, " ", while your code replaced the underscores with the empty string, "", which was at least part of the problem.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '597222' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '597222') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '597222') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
