Assaf1
String parsing formula
How can I define formula to import the right srting after the last "_"?
For example:
Column1Formula
CONTINUITY_P_TXP_POS_400UA_TI1310PTI1310P
CONTINUITY_DIG_NEG_2MA_CCLK CCLK
Thaks in advance!
Assaf
pmroz
Re: String parsing formula
Words will get you there.  This formula will do the trick:
c = Words(:Column 1, "_");
d = c[N Items(c)];
uday_guntupalli
Level VIII
@Assaf1
         Do you need the formula to be in a table ? I can offer the following solution that works :
dt = Current Data Table(); // Ensure your data table is open and it is current
Vals = :Column 1 << Get Values;  // Get Values out
Res = List(); // Define empty list
for(i = 1 , i <= N Items(Vals), i++,
	 Test = Words(Vals[i],"_"); // Words is the function that will split your string by delimiter
	 Insert Into(Res,Test[N Items(Test)]);
Show(Res);
Alternatively,
     You could use a similar approach to parse out the strings separated by the delimiter in a column formula as well, by using the following as a column formula:
     But then, I can't really think of a way to get the last string out in the column formula. Hope this helps some. Maybe look at "Substr" function - it might help
Best
Uday
pmroz
d = c[N Items(c)];
Assaf1
Thanks a lot for your suport
It's work!
Similarly, you could use the Word function to get the last "word" using an index of -1 (i.e. count backwards from the end). This just saves you from needing any JSL variables/lists.
Word( -1, :Column 1, "_");
Justin
pmroz
JSL continues to surprise me!  Great solution Justin.
