HubP_SDe
String formatting to customize chart Titles and Annotations
Dear Community,
Now that we reached a nice Application, we would like to customize charts Titles and add som Text Annotations, like Project & Scenario name, Description...
To make it nicer, I tried to insert a Line Feed control code into the string but it is displayed instead:
		Dispatch(
			"Distributions",
			OutlineBox,
			{Set Title( Eval( Char ( scenario ) ) || "\nIST Distribution" )}
In idea if this is even feasible?
Thanks
Stéphane DELACROIX
Senior Simulation & Planning Engineer
Re: String formatting to customize chart Titles and Annotations
The escape sequence for new line is "\!n"
It is documented in the Scripting Guide found in the JMP Documentation Library found under the Help pull down menu.
I did a "Whole Word" search on "new line" and found a reference to it
Write() sends the message that you specify to the log. Write() is the same as Print() except
that it suppresses the quotation marks around the text string, and it does not start on a new
line unless you include a return character yourself with the \!N escape sequence.
myText = "Here is a message.";
Write( "Here is a message." );
Here is a message.
Write( myText || " Do not forget to buy milk." ); // use || to concatenate
Write( "\!NAnd bread." ); // use \!N for return
Here is a message. Do not forget to buy milk.
And bread.
The sequence \!N inserts the line breaking characters that are appropriate for the host
environment. For an explanation of the three line breaking escape
HubP_SDe
Thanks a lot Jim, it worked fine!
Do you know where and how I could have found this information? (scripting index or online help, but what to search for?)
Stéphane DELACROIX
Here is a message.
And bread.
HubP_SDe
Wonderful!
You just made me discover this huge PDF documentation.
I only used the Scripting Index, in which this same search gives nothing ;)
Thanks again
Stéphane DELACROIX
