modelFit
String Parsing Question
Dear Community,
I am receiving data with identifying information in 1 cell.
Names Default to Here(1);
dt = New Table("Sample",
add rows(2),
	New Column( "Field_9630", Character, "Nominal" )
dt:Field_9630 << Set Values({"Customer: Mr A LoyalProduct: Cabinet HardwareRegion: Suburban New Dev", "Customer: Jenifer B Ashley LeighProduct: LumberRegion: Suburban Existing"});
The target is to produce three columns - Customer, Product, Region
dt2 = New Table( "Sample 2",
	Add Rows( 2 ),
		Character,
		"Nominal",
		Set Selected,
		Set Values(
		Set Display Width( 132 )
	New Column( "Customer",
		Character,
		"Nominal",
		Set Values( {"Mr A Loyal", "Jenifer B Ashley Leigh"} )
	New Column( "Product",
		Character,
		"Nominal",
		Set Values( {"Cabinet Hardware", "Lumber"} )
	New Column( "Region",
		Character,
		"Nominal",
		Set Values( {"Suburban New Dev", "Suburban Existing"} )
Many thanks in advance!
Sincerely,
MG
Thierry_S
Re: String Parsing Question
It is always challenging to parse strings when you do not have clear delimiters.
Assuming that the input string will always contain the keywords "Customer:", "Product:", and "Region:", you can use the approach below:
  1. Replace the keywords with "," using the SUBSTITUTE() function
  2. Parse the relevant information using the WORD() function
  3. Clean up the resulting strings with the TRIM() function.
New Table( "Sample_PARSED",
	Add Rows( 2 ),
		Character,
		"Nominal",
		Set Values(
		Set Display Width( 726 )
	New Column( "TEMP",
		Character,
		"Nominal",
		Formula(
			Substitute( :Field_9630,
				"Customer:", ",",
				"Product:", ",",
				"Region:", ","
	New Column( "Column 2",
		Character,
		"Nominal",
		Formula( Trim( Word( 1, :TEMP, "," ) ) ),
		Set Display Width( 157 )
	New Column( "Column 3",
		Character,
		"Nominal",
		Formula( Trim( Word( 2, :TEMP, "," ) ) )
	New Column( "Column 4",
		Character,
		"Nominal",
		Formula( Trim( Word( 3, :TEMP, "," ) ) ),
		Set Display Width( 200 )
I hope it helps.
Best,
TS
Thierry R. Sornasse
Thierry_S
	Add Rows( 2 ),
		Character,
		"Nominal",
		Set Values(
	New Column( "TEMP",
		Character,
		"Nominal",
		Formula(
				"Customer:", ",",
				"Product:", ",",
				"Region:", ","
		Character,
		"Nominal",
		Character,
		"Nominal",
		Character,
		"Nominal",
I hope it helps.
Best,
TS
Thierry R. Sornasse
modelFit
@Thierry_S Thanks for the quick reply and solution. Much appreciated!
