String Operations after Reading from Excel
I am reading a cell from Excel which is read by JMP as - "['299','523']". I need the string to be manipulated to be {"299","523"}. I am not able to do this.
Any help would be appreciated. There probably is an easy solution but I cannot figure it out.
Thanks,
Neel
Re: String Operations after Reading from Excel
Use the Substitute() function to ca hange characters
Hi Jim,
I tried that already, but I cannot replace " (double quotes) in the string with an empty space. Any suggestions?
This: temp = Substitute(string,""\", " "); doesn't work and I get errors.
Thanks!
Substitute should work fine here
str = "['299','523']";
str2 = Substitute(str, "'", "\!"", "[", "{", "]", "}");
Write(str2);
You can find escape sequences for quoted strings here Scripting Guide > JSL Building Blocks > JSL Syntax Rules
