I would like to plot Y by X continous variables. X represent unit time., and Y is mean signal at each time point in X (please see below). I would like to add standard deviation bars to each point. How can I do it in JMP pro 14?
the only thing u left out is that in order to color the points according to the group variable, you have to drag that variable over to the "color" tab on the right side of the graph builder window
