skollcruz23
Stack output table name
I have a script that dynamically parses some of the info for stack table and would like to store the stack table as a new data table.
ystr1 = ":INFRASTRUCTURE Value, :INFRASTRUCTURE Value 1"
infr = "Infrastructure Value";
data = "PPT";
output_name = "infra_updated.jmp";
gbStr = EvalInsert("dt << Stack(
columns(
^ystr1^
Source Label Column(^infr^ ),
Stacked Data Column(^data^),
Output Table(^output_name^ )
Eval(Parse(gbStr));
I am getting the following error
Name Unresolved: infra_updated..jmp in access or evaluation of 'infra_updated.jmp'
Unable to figure out why EvalInsert doesn't work for Output Table
Re: Stack output table name
Quotes need to be around the Output Table() specified name.  Therefore, they need to be added to the string value for your output_name variable
ystr1 = ":INFRASTRUCTURE Value, :INFRASTRUCTURE Value 1";
data = "PPT";
output_name = "\!"infra_updated\!"";
gbStr = Eval Insert(
	"dt << Stack(
columns(
^ystr1^
Eval( Parse( gbStr ) );
Jim already gave the reason what is going wrong in your script. I would suggest you use other methods than Eval(Parse()) as it can be extremely difficult to debug and you don't have syntax highlighting in script editor
cols = {"age", "height"};
cols = {"INFRASTRUCTURE Value", "INFRASTRUCTURE Value 1"};
data = "PPT";
output_name = "infra_updated";
dt_stacked = dt << Stack(
	Columns(Eval(cols)),
	Source Label Column(infr),
	Stacked Data Column(data),
	Output Table(output_name)
data = "PPT";
	"dt << Stack(
columns(
^ystr1^
skollcruz23
Thank you for explaining the issue.
data = "PPT";
skollcruz23
I am fairly new to JSL scripting and still in the process of getting familiar with it. But I agree your solution looks more easy to debug. Thanks
skollcruz23
I tried your solution but i am seeing this error.  I do have the correct column names in the list.
"Column not found in access or evaluation of 'Stack' , Bad Argument"
For me it works fine in JMP18 (and 17) when I test it with the example I left in the code
data = "PPT";
Are you sure the column names are written correctly and they are in a list?
