Splitting survival curve
JMP 17
Dear all,
I would appreciate your help with the following issue.
I have a database of ca. 300 individuals split into 3 groups. The goal is to assess their survival over time. I have generated a Kaplan-Meier survival curve (max follow-up time 35 years) and log-rank is showing p<.05. Now I would like to split it and look into whether survival rates between those 3 groups differ at different timepoints (5, 10, 15 years). How do I do that in JMP?
J.
peng_liu
Re: Splitting survival curve
As you may be already aware of, neither Survival nor Life Distribution provide answers to that question.
If your data is right censored, such that, for example, at time point 5, all failures occurred before 5, then your objective is reduced to comparing three proportions. I.e. the proportions of survival of three groups at time 5. And you should be able convert your data and conduct an equivalent analysis, e.g. logistic regression.
If your data is more complicated than that, and converting the problem to comparing proportions is not feasible, things may get complicated. And it could become a new research topic. (I saw two publications relevant: [1] and [2]) But meanwhile, you may use approximation. For example, you have three point estimates of survival probabilities at time 5, and you have their standard errors, and the approximation becomes comparing three random normal variables, and it seems to involve multiple comparisons.
peng_liu
Thank you very much! I really appreciate your help.
J.
