B1234
Splitting a string to extract numbers
Hi ,
I have a string that is character and I want to extract a 4 number section. The position of the numbers may change
An example of the string may be
value ="Hello 0123 example";
I have tried this but only works if the numbers are in the correct position.
extract=substr(value,7, 4);
As the position of the number will change how can I extract this?
Re: Splitting a string to extract numbers
You could try something like this:
string = "Hello 0123 example";
matches = Regex Match(
	string,
	"[0-9]{4}",
// ASSUMES that you are interested only in the first 4-digit number, if there is more than one
extractedNumber = matches[1];
This returns "0123".
Please note that it still returns "0123" if your input string is "Hello 01234 example".
One other option is to use Regex instead of Regex Match (there are also more options how this could be done, but I think Regex and Regex Match are the easiest ones)
four_num = Regex(string, "\d{4}"); //0123
See https://regex101.com/r/26hBdb/1 for how regex this works if you are not familiar with it.
	string,
	"[0-9]{4}",
B1234
This worked like a charm. Thank you so much!
This is probably better because you don't have to grab the first match.  Thanks!
B1234
ok thank you @Aurora_TiffanyD and @jthi !
