WanCine
Split Array
1. Any ideas how to split a = {"c", "d","e"}; into a= {"c"}, {"d"},{"e"}; ? Currently when I did Concat Items (a, ","); , the output will be "c,d,e" instead of "c","d","e" .
2. Concat Items did apply after letter c. However, what if I want to concat "," before c such as ",c,d,e"?
3. Is there any possibilities to combine semicolon together with other strings? For example, " " "|| water || bend || "," || " " " , thus the output will be "water bend,"
Re: Split Array
That would be read same as if you "removed" first quotes (as it is string) and replaced all \!" with single ".
Check log after running this script (and also created datatable, it will add a_string value to one cell)
a_list =  {"c", "d", "e"};
show(a_list);
a_string = "\!"" || Concat Items(a_list, "\!",\!"") || "\!"";
show(a_string);
write("\!NWrite print: "||a_string);
dt = New Table("newtable",
	Add Rows(1),
	Compress File When Saved(1),
	New Column("col", Character, "Nominal", Set Values({""}))
column(dt, "col") << Set Each Value(a_string);
write();
I have had my challenges with strings in JMP and it has depended on the use case what I have had to do to manage with them to add quotes.
Jeff_Perkinson
Re: Split Array
@WanCine wrote:
I'm having trouble making sense of this question because a= {"c"}, {"d"},{"e"}; isn't valid JSL. There's no data structure which will hold three separate lists like that. Can you clarify exactly what you're trying to do?
Try this:
a = {"c", "d", "e"};
z = "," || Concat Items( a, "," );
I think @jthi pointed out that you can escape quotation marks with \!".
foo = " \!" "|| "water " || "bend" || "," || " \!" ";
-Jeff
Re: Split Array
You can escape quotes with \!"
a = "\!"" || Concat Items(a, "\!",\!"") || "\!"";
write(a);
Also check out https://www.jmp.com/support/help/en/15.2/index.shtml#page/jmp/jsl-syntax-rules.shtml
WanCine
Re: Split Array
Hi Jthi,
Thanks for the reply. I believe your reply refer to question no.3 only. I did try that \!" earlier. But when check the return value, it shown as below figure. So, this return value should be read as "c, d, e" and not as per shown below. Correct me if I am wrong.
Re: Split Array
show(a_list);
show(a_string);
	Add Rows(1),
write();
Jeff_Perkinson
Re: Split Array
@WanCine wrote:
Try this:
-Jeff
