Valerio
Spec Limits as Variable
Good afternoon.
I am trying to specify Spec Limits as a Variable and for some reason it does not work.
Please see below working code with explicit spec values =>
Data_Table_1:Column_with_Spec << Set Property( "Spec Limits", {LSL( 1 ), USL( 2 ), Show Limits( 1 )} );
Please see below not-working code with spec values as variables =>
LSL_var = 1;
USL_var = 2;
Data_Table_1:Column_with_Spec << Set Property( "Spec Limits", {LSL( LSL_var ), USL( USL_var ), Show Limits( 1 )} );
(If I use the variables "LSL_var" and "USL_var" in an "If" condition in a Formula they work.)
Why is this not working?
Thanks.
