Sorting by columns
Sorry to display my ignorance but how do I sort a datafile by column entries?
Duane_Hayes
Staff (Retired)
Re: Sorting by columns
As stated above,
If you only want to sort by one column, you can right mouse click on the header of the column and the second to the last option is sort. To sort it the descending, sort it again with the right mouse click.  Alternatively, Tables->Sort will work, and is the way to go for sorting by multiple columns.
Duane Hayes
If you look under the table menu, there are a bunch of commands for reorganizing data tables. One of these is sort. You can add the column(s) of interest and specify ascending or descending. JMP can then either replace your table or create a new one.
One way is go to Table > Sort
If you only want to sort one column, you can right mouse click on the header of the column and the second to the last option is sort. To sort it the descending, sort it again with the right mouse click.
Duane_Hayes
Staff (Retired)
As stated above,
Duane Hayes
