whom
Sorting a column with a script
I have a file (mydata.jmp) and I manually sort the Temperature column (right click, and then Sort).
I'm trying to automate this in a jmp script.  what's the correct command so the column is sorted and the new file retains the original file name.  I have tried a few commands and the result of the sort command creates a new unnamed file, which is NOT what I want.
ms
Super User (Alumni) ms
Re: Sorting a column with a script
Try this syntax:
dt << sort( by( col ), Replace Table );
ms
Try this syntax:
whom
Adding the Replace Table did the trick.  Thanks!
