shampton82
Some way to get constants from the Johnson Transformation
Hey everyone,
I was trying to develop a script that would transform a column using the Johnson Transform and then be able to grab the constants from the formula to be able to put back into the inverse formula so I could use that to calculate the spec limits in their original units.
So the work flow will be like this
select a column-> transform using Johnson-> Run Control Chart-> see what the control limits are and enter into my user interface,-> have spec limits spit out in original units-> run control chart again in original units and input calculated from previous steps.
I think I can handle most of this but I'm stumped on how to grab the constants from the transform equation.
So from here
to put in here
Thanks for any ideas!
Steve
Re: Some way to get constants from the Johnson Transformation
Extract the formula into an expression and then take values from there. After you have the expression, you can then for example use Arg() to pick values from the formula
new_cols = dt << New Formula Column(
	Operation(Category("Distributional"), "Johnson Normalizing"),
	Columns(:weight)
new_col = Remove From(new_cols, 1)[1];
f_expr = Column(dt, new_col << get name) << Get Formula;
Show(Arg(f_expr, 1), Arg(f_expr, 2));
There are few posts regarding this in community, here is one JMP > JSL > Get Formula > Extract Parameters
You have changed some of the statements that should not have been changed.  I have commented out the inappropriate lines, and changed them back.  I have also added in functionality that runs a control chart and strips off the Control Limits and uses them as the values to transform back into the original distribution.
dt=current data table();
theColumn = dt<<get selected columns("string");
if(n items(theColumn)!=1,
	throw("Incorrect number of columns selected, must be just one");
		nw=new window("calculate control limits limits",
						Panel Box("actions",
							Hlistbox(
									bb1=Buttonbox("press to get Limits",
										nebvalue1=neb1<<get;
										nebvalue2=neb2<<get;
										obj=Distribution(
											Continuous Distribution(
												Column( as column(theColumn) ),
												Process Capability( Use Column Property Specs ),
												Fit Johnson(save distribution formula)
											invisible(1),
												Dispatch( {eval(theColumn)}, "Process Capability", OutlineBox, {Close( 1 )} )
										obj<<close window;
// Run the Control Chart and strip off the LCL and UCL
ccb = /* Control Chart Builder(
	Variables( Y( column(ncols(dt)) ) ),
	Show Control Panel( 0 )
	Variables( Y( column(ncols(dt)) )  ) ,
	Set Subgroup Size( 5 ),
// Get the Target LCL and Target UCL from the Displayed Report
theTarget_lcl = (report(ccb)[NumberColBox("LCL")]<<get)[1];
theTarget_ucl = (report(ccb)[NumberColBox("UCL")]<<get)[1];
ccb << close window;
										// Find the back transform of the calculated mean of the transformed distribution
										theTargetCol = Column( dt, N Cols( dt ) ) << get name;
										theFormula_lcl = Char( As Column( dt, theTargetCol ) << get formula );
										//theTarget_lcl = nebvalue1;
										// Change the reference to the original column used in the transformation to _X_
										// so it can be used in the back transform
										Substitute Into( theFormula_lcl, ":"|| theColumn[1], "_X_" );
										// The formula needs to create a memory variable to allow for comparison.
										// Add the resulting variable name to be the resulting variable when the
										// formula is executed
										theFormula_lcl = "theResult_lcl = " || theFormula_lcl || ";";
										// Successive Approximation will be used to get the back transform
										// Use the min and max of the original column to start the approximations
										theMax = Col Max(as column(theColumn) );
										theMin = Col Min( as column(theColumn)  );
										// Loop through the approximations for up to 100 loops to find the value
										For( i = 1, i <= 5000, i++,
_X_ = Mean( theMax, theMin );
											//_X_ = thetarget_lcl;
											Eval( Parse( theFormula_lcl ) );
											If(
												theResult_lcl > theTarget_lcl, theMax = _X_,
												theResult_lcl < theTarget_lcl, theMin = _X_,
												Break()
neb1 << set( _X_ );
										// Display the findings in the log
										Show( i,_x_,theTarget_lcl, theResult_lcl);
										//theTargetCol = Column( dt, N Cols( dt ) ) << get name;
										theFormula_ucl = Char( As Column( dt, theTargetCol ) << get formula );
										//theTarget_ucl = nebvalue2;
										Substitute Into( theFormula_ucl, ":"|| theColumn[1], "_X_" );
										theFormula_ucl = "theResult_ucl = " || theFormula_ucl || ";";
										For( i = 1, i <= 15000, i++,
											//_X_ = thetarget_ucl;
											Eval( Parse( theFormula_ucl ) );
											If(
												theResult_ucl > theTarget_ucl, theMax = _X_,
												theResult_ucl < theTarget_ucl, theMin = _X_,
												Break()
										Show( i,_x_,theTarget_ucl, theResult_ucl);
neb2 << set( _X_ );
										neb3<<set(theResult_lcl);
										neb4<<set(theResult_ucl);
								Vlistbox(
									textbox("LCL"
									textbox("UCL"
								Vlistbox(
									neb1=numbereditbox(
									neb2=numbereditbox(
								Vlistbox(
									neb3=numbereditbox(
									neb4=numbereditbox(
9 REPLIES 9
	Columns(:weight)
shampton82
Thanks @jthi !
I modified your script to pull out each individual parameter as such:
	Columns(:weight)
test1=contains(char(arg(f_expr))," - (",1);
test2=contains(char(arg(f_expr)),"))",1);
c1=num(substr(char(arg(f_expr)),num(test1)+4,num(test2)-num(test1)-4));
test3=contains(char(arg(f_expr))," / ",1);
test4=contains(char(arg(f_expr)),") *",1);
c2=num(substr(char(arg(f_expr)),num(test3)+4,num(test4)-num(test3)-4));
test5=contains(char(arg(f_expr))," * ",1);
test6=contains(char(arg(f_expr)),"+",1);
c3=num(substr(char(arg(f_expr)),num(test5)+4,num(test6)-num(test5)-4));
c4=Arg(f_expr, 2);
Working great so far!
Steve
For something like this all the Expression functions can be very useful
N Arg(f_expr);
Head(f_expr);
Head Name(f_expr);
Head(Arg(f_expr, 1));
Head(Arg(Arg(f_expr, 1), 1));
Sometimes you might want to add Extract Expr into the mix
Extract Expr(f_expr, (:weight - Wild()));
One method that I have used successfully is to use Successive Approximations to find the value in the original distribution for a value from the transformed distribution.  It basically takes values from the original distribution and passes it through the formula created by the transformation formula until it finds a match with the calculated value from the transform distribution.  Here is an example that fits a Johnson distribution, finds the mean of the transformed column and then finds the value in the original distribution for that transform mean value.  In the examples case, it just writes the back transformed value to the log.
dt =
// Open Data Table: Semiconductor Capability.jmp
// → Data Table( "Semiconductor Capability" )
Open( "$SAMPLE_DATA/Semiconductor Capability.jmp" );
theColumn = "NPN1";
Distribution(
		Dispatch( {"NPN1"}, "Process Capability", OutlineBox, {Close( 1 )} )
theFormula = Char( As Column( dt, theTargetCol ) << get formula );
theTarget = Col Mean( Column( dt, theTargetCol ) );
Substitute Into( theFormula, ":"|| theColumn, "_X_" );
theFormula = "theResult = " || theFormula || ";";
For( i = 1, i <= 100, i++,
	Eval( Parse( theFormula ) );
	If(
		theResult > theTarget, theMax = _X_,
		theResult < theTarget, theMin = _X_,
		Break()
Show( theTarget, theResult, _X_, i );
shampton82
Thats really cool @txnelson !
I'll play around with this some more but looks like I can use this to feed in a target from the transformed units (vs how the script just used the column mean) and it will output the value in original units (if I'm understanding this correctly).
Steve
That is correct, or any other stat you get from the transformed distribution
shampton82
Hey @txnelson ,
I modified your script(try not to cringe to much lol) and made it so I could put in my spec limits and will get the transformed values of those limits, which is sweet.  However, for my workflow I actually need to be able to put in the spec limits from the transformed data (so post running a control chart on the transformed data) and output them in the original data values.  I follow most the code but not enough of it to feel confident trying to modify further myself so was wondering if this is a quick fix you could make in this code to basically reverse what it is currently doing?
							Hlistbox(
										obj=Distribution(
											invisible(1),
										obj<<close window;
										For( i = 1, i <= 1000, i++,
											If(
												Break()
										Show( theTarget_lcl, theResult_lcl);
											If(
												Break()
										Show( theTarget_ucl, theResult_ucl);
								Vlistbox(
									textbox("LCL"
									textbox("UCL"
								Vlistbox(
									neb1=numbereditbox(
									neb2=numbereditbox(
								Vlistbox(
									neb3=numbereditbox(
									neb4=numbereditbox(
Thanks for any input and/or help!
Steve
							Hlistbox(
										obj=Distribution(
											invisible(1),
										obj<<close window;
											If(
												Break()
neb1 << set( _X_ );
											If(
												Break()
neb2 << set( _X_ );
								Vlistbox(
									textbox("LCL"
									textbox("UCL"
								Vlistbox(
									neb1=numbereditbox(
									neb2=numbereditbox(
								Vlistbox(
									neb3=numbereditbox(
									neb4=numbereditbox(
shampton82
Thanks @txnelson !
Thanks for going above and beyond.  This works great!
Steve
