uday_guntupalli
Level VIII
Slope and Intercept calculations in JSL
@Jeff_Perkinson , @Milo ,
        This is in reference to a discussion - Slope and intercept functions
        I have found this discussion to be helpful. I am currently using JMP 13, so if there are developments made in JMP 14, I dont necessarily have access to it.
        But, here are my questions:
Clear Log() ; Clear Globals(); Close All(DataTables,"No Save");
Slope = function({x,y},{default local},
				If( !(Is Matrix( x ) & Is Matrix( y ) & N Col( x ) == 1 & N Col( y ) == 1),
					Show( "x or y arguments are not matrices or they have more than one column" );
					Throw();
					x = J( N Row( x ), 1 ) || x; // put in an intercept column of 1s
					beta = Inv( X` * X ) * X` * Y; // the least square estimates
					beta[2];
Intercept = function({x,y},{default local},
						Throw();
						beta[1];
					); // end of intercept function
x1 = 0.05417099;
x2 = 0.057730865;
y1 = 30.5885;
y2 = 31.5885;
dt = New Table();
dt << New Column("X",Numeric,Continuous,<< Set Values({x1,x2}))
   << New Column("Y",Numeric,Continuous,<< Set Values({y1,y2}));
dt << New Script("Biv",Bivariate( Y( :Y ), X( :X ), Fit Line( {Line Color( {213, 72, 87} )} ) ));
SlopeTest = Slope(Matrix({y1,y2}),Matrix({x1,x2}));
Show(SlopeTest);
InterceptTest = Intercept(Matrix({y1,y2}),Matrix({x1,x2}));
Show(InterceptTest);
    1. Why do the slope and intercept not match for the test case that I have taken w.r.t bivariate ?
    2. If the function or its implementation have a bug, would you be kind enough to offer an alternative ?
Best
Uday
cwillden
Re: Slope and Intercept calculations in JSL
Hey @uday_guntupalli,
You still got the arguments reversed.  See the screenshot:slope_int.PNG
-- Cameron Willden
vince_faller
The order of your inputs are backwards.  On the function it goes slope(x, y) and when you call you're doing slope(y, x)
Vince Faller - Predictum
cwillden
You got the arguments backward for the Slope and Intercept function.  Just reverse the order of the matrices.
-- Cameron Willden
uday_guntupalli
Level VIII
@cwillden
       While that was a good catch, that did not change the results and the function doesn't match up to bivariateimage.png
Best
Uday
cwillden
-- Cameron Willden
vince_faller
