agneshb
Simulating data with random() formula
If I have a column of data (A) and want to simulate a test result on that column (from a normal distribution(SD of 10 and mean = the number in column A), can someone confirm it is right to do it with the following formula:
Random norma()*10+A
If it's not, how can I do it?
also, is there a way to enter the SD a RSD(%)??
Agnès
stan_koprowski
Re: Simulating data with random() formula
You are on the right track.  The Random Normal function by default will use mu =0 and sigma = 1.
This can easily be changed in your formula as shown below:
7415_Screen Shot 2014-10-10 at 10.01.51 AM.png7415_Screen Shot 2014-10-10 at 10.01.51 AM.png
The Coefficient of Variation is what you need to display the RSD or %RSD.  To display the coefficient of variation look under the red triangle of Summary Statistics and select Customize Summary Statistics.
7418_Screen Shot 2014-10-10 at 10.25.42 AM.png7418_Screen Shot 2014-10-10 at 10.25.42 AM.png
Check the box next to CV and then click OK.
7419_Screen Shot 2014-10-10 at 10.27.04 AM.png7419_Screen Shot 2014-10-10 at 10.27.04 AM.png
And if you look at the distribution of both A and the simulated A we do indeed now have an normal distribution for the simulated A.
7417_Screen Shot 2014-10-10 at 10.19.24 AM.png7417_Screen Shot 2014-10-10 at 10.19.24 AM.png
Best,
Stan
stan_koprowski
Best,
Stan
agneshb
Thanks Stan!
If you find yourself going to the Customize Summary Statistics options every time you run the Distribution platform, you might be interested in knowing that you can use Platform Preferences to set the summary statistics that show up.
See Re: how to change default summary statistics displayed in distributions.
Michael Crotty
Principal Statistical Writer
Manager, Statistical Documentation
JMP Development
