viralnerd2013
Simple task - remove empty columns
Hello SAS forum,
I am trying to remove all columns in a dataset that are empty, and I cannot figure out how to do this in JMP9. Can you help? There will be variable number of patients and AA's
Data input
PatientSample
AA_1AA_2AA_3AA_4AA_5AA_6
2234Day 1AC
2234Day 11AV/M/SC
2234Day 21AC
2234Day 24AS/TC
Output
PatientSample
AA_2AA_4AA_5AA_6
2234Day 1AC
2234Day 11AV/M/SC
2234Day 21AC
2234Day 24AS/TC
ms
Super User (Alumni) ms
Re: Simple task - remove empty columns
When doing this interactively in JMP, I tend to use missing data pattern and summary. But for large tables and repeated tasks JSL script is more effective.
This should work for removing empty columns of any data type.
nc = N Col( dt );
names = dt << Get Column Names();
dt1 = dt << Missing Data Pattern( columns( Eval( names ) ), invisible );
nr = N Row( dt1 );
For( i = nc, i >= 1, i--,
  If( Col Sum( Column( dt1, i + 3 ) ) < nr,
  Remove From( names, i )
Try( dt << delete columns( names ) );
Close( dt1, nosave );
ms
nc = N Col( dt );
nr = N Row( dt1 );
viralnerd2013
Works beautifully! Thank you very much.
gbu
gbu
If you want to keep the empty column name into list, you could also process like this.
iColMax = NCol(dt);
iRowMax = NRow(dt);
null = 0;
lstDelete = List();
For (iCol = 1, iCol<=iColMax, iCol++,
    null = 0;
    col = Column(iCol);
    strColName = Column(iCol) << GetName;
For (iRow = 1, iRow<=iRowMax, iRow++,
  If (Or(IsEmpty(col[iRow]),IsMissing(col[iRow])),
   null = null + 1;
If (null == iRowMax, InsertInto(lstDelete, Eval(strColName))
dt << Delete Columns(lstDelete);
viralnerd2013
Thank you. I ran this but did not see the list, am I missing something?
gbu
gbu
If you wanna see the list, you can just use :
Print(lstDelete);
