Jackie_
Side by side distribution plots for Tall table
Is it possible to plot side by distribution plots in one graph with tall table?  something like Graph Builder?
Something like this?
BR,
Jackie
18 REPLIES 18
Re: Side by side distribution plots
Yes, Graph Builder can do that. I've attached the example below.
Jackie_
@Jed_Campbell  yes I am aware, but how to plot distribution histogram side by side in the same graph?
Sorry, @Jackie_, I must be misunderstanding what you're looking for. Or, perhaps I chose a bad data set with not enough data to make the shape of a histogram. Here's another example of side by side histograms in the Graph Builder. If this isn't what you're looking for, can you please clarify?
Jackie_
@Jed_Campbell
I think the data table I have is in tall format. So the tests are grouped in columns. Is there a way to plot side by side in graph builder with tall table? I have attached below
If you want a histogram for specific columns to be placed side by side, just drag all of them to the X axis and change the display to be a Histogram
@Jackie_
You can use the Tables...Stack command to change the orientation/format of your data. The attached workflow (assuming you have JMP 17 or greater) walks through how. I also added a local data filter, since the stacked data made the graph have very wide limits otherwise.
Jackie_
Thanks @Jed_Campbell , I see you transposed the table. I think this approach works but wondering what if there's tall data table with >1M Rows?. I think transposing into Data columns wouldn't be best.
For ex: I stacked 252k rows and the final data table resulted 56M rows
Here is another way to do it
// Open Data Table: big class.jmp
// → Data Table( "big class" )
Open( "/C:/Program Files/SAS/JMPPRO/16/Samples/Data/big class.jmp" );
nw = New Window( "",
	H List Box(
		Distribution(
			uniform scaling( 1 ),
			Continuous Distribution(
				Column( :height ),
				Quantiles( 0 ),
				Summary Statistics( 0 ),
				Outlier Box Plot( 0 )
			by( :age )
You can also do this via the Oneway flavor of Fit Y By X:
// Open Data Table: Semiconductor Capability.jmp
// → Data Table( "Semiconductor Capability" )
Open( "$SAMPLE_DATA/Semiconductor Capability.jmp" );
// Report snapshot: Semiconductor Capability - Fit Y by X of NPN1 by lot_id
Data Table( "Semiconductor Capability" ) << Oneway(
	Y( :NPN1 ),
	X( :lot_id ),
	Histograms( 1 )
