TWE
TWE
Show zero percent in bar chart
I build a bar chart in percent and need also to display zero percent (in the sniplet group2).
dt = New Table("Test");
dt << new column ("C", numeric, Continuous);
dt << new column ("D", numeric, Continuous);
dt << new column ("E", numeric, Continuous);
:C << set values([1,2,3]);
:D << set values([1,2,3]);
:E << set values([1,0,0.5]);
dt << new column ("Percent", numeric, Continuous, Format( "Percent", 15, 3 ), Formula(:E/:D));
dt << Graph Builder(
	Size( 534, 454 ),
	Variables( Y( :Percent ), Group X( :C ) ),
	Elements( Bar( Y, Legend( 4 ), Label( "Label by Value" ) ) ),
		Dispatch(
			"Percent",
			ScaleBox,
			{Min( -0.113265306122449 ), Max( 1.08673469387755 ), Inc( 0.2 ),
			Minor Ticks( 0 )}
Thanks for any help!
jules
Re: Show zero percent in bar chart
Hi @TWE,
I'm not aware of a way to force JMP to display the label for a truly 0 value. It's a bit of a workaround, but what I've done in the past is add a tiny amount to a value so that jmp will round to 0 and display that rounded value. For instance, using your example, by setting the value of :E[2] to 0.000000000000001 rather than 0, the 0% label displays on the graph:
:E << set values([1,0.000000000000001,0.5]);
	Size( 534, 454 ),
		Dispatch(
			"Percent",
			ScaleBox,
			Minor Ticks( 0 )}
jules
Hi @TWE,
	Size( 534, 454 ),
		Dispatch(
			"Percent",
			ScaleBox,
			Minor Ticks( 0 )}
TWE
TWE
Thanks this works well!
Another possible approach can be found in this link:
https://community.jmp.com/t5/Discussions/force-all-histogram-levels-on-bar-graph-even-if-count-0/m-p...
It should apply to percents, but I have not tried that.
Dan Obermiller
