I am working with a large data set, and I am using Graph Builder to display the results. My problem is that if I use lines on Graph Builder to display the data, there is some smoothing taking place, and the shape of the line does not accurately represent the data. If I use dots on Graph Builder, the data is accurate, but it is a little hard to see. I can use the Overlay platform to achieve lines that accurately display the fine shape of the data, but the Overlay platform does not filter data as cleanly as in Graph Builder.
Does anyone have any suggestions about how I can use Graph Builder to accurately display the fine shape of the data? I am using JMP11.
dt = New Table( "Data",
Add Rows( 1000000 ),
New Column( "X", Numeric, Continuous, Format( "Best", 12 ), Formula( Row() ) ),
New Column( "Y", Numeric, Continuous, Format( "Best", 12 ), Formula( Sequence( 1, 4, 1, 100 ) ) ),
New Column( "Group", Numeric, Ordinal, Format( "Best", 12 ), Formula( Sequence( 1, 4, 1, 1 ) ) )
graphLines = dt << Graph Builder(
Variables( X( :X ), Y( :Y ), Group Y( :Group ) ),
Elements( Line( X, Y, Legend( 7 ), Row order( 0 ), Summary Statistic( "Mean" ) ) ),
Local Data Filter( Location( {0, 0} ), Add Filter( columns( :Group ) ), Mode( Select( 0 ), Show( 1 ), Include( 1 ) ) ),
Dispatch( {}, "Graph Builder", OutlineBox, {Set Title( "Graph Builder with Lines" )} ),
Dispatch( {}, "X", ScaleBox, {Min( 335000 ), Max( 338000 ), Inc( 200 ), Minor Ticks( 1 )} )
graphDots = dt << Graph Builder(
Elements( Points( X, Y, Legend( 8 ), Jitter( 0 ) ) ),
Dispatch( {}, "Graph Builder", OutlineBox, {Set Title( "Graph Builder with Dots" )} ),
Dispatch( {}, "X", ScaleBox, {Min( 335000 ), Max( 338000 ), Inc( 200 ), Minor Ticks( 1 )} ),
Dispatch( {}, "400", LegendBox, {Position( {0} )} )
overLines = dt << Overlay Plot(
X( :X ),
Y( :Y ),
Grouping( :Group ),
Connect Points( 1 ),
SendToReport( Dispatch( {}, "101", ScaleBox, {Min( 335000 ), Max( 338000 ), Inc( 200 ), Minor Ticks( 1 )} ) )
graphLines << Journal;
graphDots << Journal;
overLines << Journal;
