kmouloua
How can i open "stdf" files in JMP?
How can i open "stdf" files in JMP? These are tester files that contains data logs.
ian_jmp
Level X
Re: How can i open "stdf" files in JMP?
Reading STDF files directly into JMP requires an add-in. There are two providers that I know of:
http://predictum.com
http://www.sprysoftware.net
ian_jmp
Level X
jy8
jy8
Re: How can i open "stdf" files in Jump?
QuickLoad-JMP from Spry Software
kmouloua
Thanks for the links. I will try it out. Again thanks
