Ella
Short cut to apply same test to all groups
Dear JMP USers,
Is there any short way to apply same test to all groups.
For example i have distributions for 8 groups. I try to check whether each group comes form a normal dist.
Is there any short way to apply goodness of fit test to all groups at the same time with one click, or do i have to use red triangle and apply goodness of fit test one group by another?
Re: Short cut to apply same test to all groups
JMP has a universal feature that allows you to "Broadcast" the selections you are making to all of the objects in a report.  Just hold down the CNTL key as you make the selection and the choices you make will be repeated on all of your histograms, or goodness of fits etc.  Here is the Tip of the Day item on this capability
