AT
AT
Setting a variable name within a for loop
I like to set variable names such as name1, name2,... in a for loop with the following arrangement:
name1 = ntable;
name2 ="A"||"_"||Flow[1];
name3 ="A"||"_"||Flow[2];
and so on.
I made a below script and got  some error:
name1 = ntable;
for (i=1, i<=Nitems, i++,
 Eval(
 Parse(
 "name"||char(i+1) = "A" ||"_"|| Flow[i];
I appreciate your help. Thanks.
Jeff_Perkinson
Re: Setting a variable name within a for loop
What exactly are you struggling with? Are you receiving an error that you don't understand? I've shown the loops above that will work for you.
I suggested earlier that you use a list instead of trying to create indexed JSL variable names. I don't see anything in the code you posted here that suggests that a list won't work for you. I'd strongly encourage you to use lists instead.
flow = {"one", "two", "three", "four", "five"};
names = {};
files = {};
For( i = 1, i <= N Items( flow ), i++,
	names[i] = "A_" || flow( i );
	files[i] = Open( "$Documents/JMP/A_" || Flow[i] || ".jmp" );
	Create Excel Workbook( "$Documents/JMP/" || product_name || "_" || one_stage || ".xlsx", files, listexcelsheet );
-Jeff
You are not using the correct syntax for the renaming of a column.  Here is an example taken directly from
    Help==>Scripting Index==>Column Scripting
:Age << Set Name( "Time" );
Jeff_Perkinson
@txnelson inteprets your question differently than I do.
I think you want to create a series of JSL variables with an index number as a part of the variable name.
You can do that but you'll need to build the entire expression as a string before you try to Parse() it.
Like this:
flow = {"two", "three", "four"};
name1 = "A_one";
	Eval( Parse( "name" || Char( i + 1 ) || "= \!"A_" || flow[i] || "\!";" ) )
However, I'm not sure why you'd want to do this instead of using a list or associative array which has the indexing built in.
names = {};
names[1] = "A_one";
	names[i + 1] = "A_" || flow[i]
Show( names[1], names[2], names[3], names[4] );
-Jeff
AT
AT
Thanks Jeff. Both works fine but I like first one since my code is based on that definition. Instead of name1, I also like to define
name1jmp = "$Documents/JMP/" || "A" || "_" || Flow[i] || ".jmp";
Can you help me how to add that to previous script? Thanks
Jeff_Perkinson
The technique is exactly the same. You're building up a string that you're going to parse into an expression and evaluate it.
One thing that might be confusing you is the \!" below. Because you need your string to contain a " you need to escape it using \!.
name1 = "A_one";
	expr_string = "name" || Char( i + 1 ) || "jmp = \!"$Documents/JMP/" || "A_" || Flow[i] || ".jmp\!"";
	Show( expr_string );
	Eval( Parse( expr_string ) );
-Jeff
AT
AT
Thank you very much Jeff. I need a bit more help after I got the first part. Here is the script that works fine below:
If( Nitems == 5,
name1 = ntable;
name2 = "A" || "_" || Flow[1];
name3 = "A" || "_" || Flow[2];
name4 = "A" || "_" || Flow[3];
name5 = "A" || "_" || Flow[4];
name6 = "A" || "_" || Flow[5];
name1jmp = "$Documents/JMP/" || "A" || "_" || Flow[1] || ".jmp";
name2jmp = "$Documents/JMP/" || "A" || "_" || Flow[2] || ".jmp";
name3jmp = "$Documents/JMP/" || "A" || "_" || Flow[3] || ".jmp";
name4jmp = "$Documents/JMP/" || "A" || "_" || Flow[4] || ".jmp";
name5jmp = "$Documents/JMP/" || "A" || "_" || Flow[5] || ".jmp";
file1 = Open( ntablejmp );
file2 = Open( name1jmp );
file3 = Open( name2jmp );
file4 = Open( name3jmp );
file5 = Open( name4jmp );
file6 = Open( name5jmp );
listx = Eval List( {name1, name2, name3, name4, name5, name6} );
listexcelsheet = Eval List( {name1, name2, name3, name4, name5, name6} );
Create Excel Workbook( "$Documents/JMP/" || product_name || "_" || one_stage || ".xlsx", listx, listexcelsheet );
I am trying to create a for loop so that it works for any Nitems. I am using MAC machine and that's why it has be done this way. Thanks for all your continuous suppprt.
Jeff_Perkinson
names = {};
files = {};
-Jeff
AT
AT
Thanks Jeff. I tried your last script and changed the files and listexcelsheet to names and works perfectly. Thanks again for all your support.
