jpollock
Setting SPC control limits based on an initial set amount of data points in JMP?
Hi fellow JMP users.
In Minitab when I wanted to set the Control limits for an SPC chart based on the first "x" amount data points (e.g. 10) I could do this very easily using the 'stage' feature. Any future data points over and above the initial stage would retain these control limits.
Being relatively new to JMP I was curious how setting the control limits based on the first "x" amount of data points is best achieved.
Can anyone advise?  Many thanks.
Re: Setting SPC control limits based on an initial set amount of data points in JMP?
There are multiple ways to accomplish this.  I suggest starting with the Excluded Row State method.  It is the 4th method detailed in this blog post.
4 ways to use fixed/baseline (historical) control limits in Control Chart Builde... - JMP User Commu...
