cbaril
Set desirability for multiple responses
I need to optimise process conditions and I would like to give equal importance to 3 responses A, B and C.
Do I need to set the importance of each as 0.33 or as 1?
I tried both and do not get the same results.
Thank you in advance for your support.
Kind regards,
Claire
Re: Set desirability for multiple responses
You do not need to specify the Importance for your responses if they are equally important. JMP assumes they are the same.
cbaril
Hello again,
I repeated and get the same results now.
To conclude I think I made a mistake, both options give the same results.
Kind regards,
Claire
