jmiller
Set Seed for Anderson-Darling Simulated p-Value
I am wondering if it is possible to set the seed for the Anderson-Darling Goodness-of-Fit test in the JMP "Distribution" platform. I'd like to be able to replicate the Anderson-Darling simulated p-value result every time I run the script.
I am open to scripting solutions.
I am using JMP 16.2.0.
Thank you,
Justin
Re: Set Seed for Anderson-Darling Simulated p-Value
There might be other options, but Random Reset seems might work
dt = Open("$SAMPLE_DATA/Cities.jmp");
obj = Distribution(Column(:CO));
Random Reset(112);
obj << Fit Lognormal(Goodness of Fit(1));
wait(1);
Random Reset(112);
Random Reset(112);
wait(1);
Random Reset(112);
